ok, after much research, i still need help knowing which UV system to purchase/install
Jenmachen
75
West Monroe, LA
I am pretty good at researching things, but there is very little info provided for an indoor residential pool. (I'm used to being the outlier)
There are so many choices. And I cannot even seem to narrow it down to whether a low pressure or medium pressure system is needed. My pool stays pretty darn perfect, with the only exception being a consistent creeping up of my CC's. Six kids has always made our family a bit on the large size, and now I keep getting new grandkids too......the battle between me and my CC's is only getting worse. The SLAM's are getting more frequent and are taking longer to resolve the CC's. Yesterday my youngest kid had her yearly "end of the school year" pool party. This weekend, my youngest granddaughters will have their birthday party. It's never ending. (By the way, I'm not complaining about the pool usage. I love it!! Only complaining about the amount of bleach I am needing to dump in there to resolve the CC's)
So, here I am asking the pool gods, to please help me make a decision that will specifically target the CC's of an indoor residential pool. Low or Medium pressure? Which brands are the best? I'm ready to do this thing.
TL/DR - low pressure mercury or mercury-amalgam bulbs are your best bet.
For a residential pool turn-key system, you’re most likely only going to find low pressure UV lamps as the standard. They are safer to operate and they produce mostly UV-C radiation and lots of heat (about 30-40% of the electrical energy is converted to UV-C, the rest is longer wavelength visible, heat, and electrical loss).
What’s key is how the UV is implemented. In a standard, single pass, straight flow design, you really need a bypass plumbing configuration to control flow and ensure as much exposure as possible. This does incur a dilution effect because you’re only exposing a fraction of the water flow to the UV source. This can be a good enough setup if you plan to run the UV continuously.
A more efficient approach is to use a larger contact tank setup where the water enters the tank from the bottom and has to flow in a centrifugal fashion so it has a long contact time with the UV source. Some of these systems are setup to inject peroxide as well so that you get the added benefit of hydroxyl radical formation.
Your biggest expense is going to be bulb replacement as they only last a year or so with constant use. So whatever route you chose, make sure you have a few bulb suppliers available. Also, grab an extra quartz sheath tub as well because those lose transparency over time too.
The second scenario you suggested with a tank set up. Is there a plug-play option on the market like that? Or is that something that has to be designed? In our small town there is nobody that knows anything about UV. I guess they are pretty common wasted upsells for many areas of the country, but they are unheard of for pools here.
A contact tank setup is something that has to be designed during pool build. I’ve not seen anything in the retail space on that.
I would simply go with a standard, commercially available unit and do the installation yourself or pay a handyman to do it. It’s not rocket science. Then simply run it and see how it works.
gotcha. yes, i have a handyman that works with me on stuff like this. thanks!
still looking for any advice on brands/makers. if anyone has some insight.
