Offline Chlorinator Tubing.. What material to use?
Navig8r
1
Ulster County NY
Installed pool last season. Trying to install offline chlorinator. Kit came with fittings and tubing, but I will not use the saddle clamp fittings. I have installed appropriate tees in place so I can use threaded fittings. Chlorinator came with tubing that is non-standard, so I want to simply buy the tubing and fittings I need.
Need 3/8" OD
What is UV resistant, and suitable with chlorinated water, that is available in small rolls (15-20'?
What have you used other than the "Hayward replacement" that seems to be only out there in overpriced 8' lengths?
TIA!
Welcome to TFP! :wave: You may have already found a product, but just in case, I found a couple quotes from similar discussions related to chlorinators, stenners, etc.
- A lot of people with Stenner pumps just use the black 1/4" PVC tubing supplied with the pump. The black tubing is UV resistive while the clear tubing will be degraded by UV.
- Parflex tubing will last a very long time, and handle anything pool chemical wise for years on end.
