Man I'm still fihgting this, how much longer can it take? i cleaned cartridge filters today after i brushed jets and skimmer.
Hello gobbler,
I'm so sorry. I can certainly read the frustration in your words, and can complete sympathize with you on it taking some time to clean the algae from your pool. Unfortunately, it takes as long as it takes as no 2 SLAMs are the same.
You are doing everything you can on your part to complete the SLAM, so just keep up the great job. Ensure you are maintaining your chlorine at, or slightly above Shock level for your CYA at all times, brush the pool once or twice a day paying particular attention to lights, steps, ladders, returns, skimmer, and the areas where the walls and the floor meet, and vacuum frequently.
If you haven't already, removed your ladder/steps out of the pool if possible, and give them a good bleach scrubbing. You also might need to check inside any light fixtures, return fixtures, etc. to ensure there isn't some algae hiding there slowing down your process.
I hope this helps. You ARE doing an excellent job, and I'm so sorry the algae is being so stubborn for you. You will get this SLAM done, I promise. Have a wonderful day![]()
If that's the case I think I see where your issue is at. Your Shock level is 31ppm for your 80 CYA so Anytime that level drops below that 31ppm level you are not high enough to kill the algae, and can backslide.
It appears you are having a 3-5ppm drop still. Try raising your Target FC level up to 34-35ppm, and never allow it to drop below 31ppm at any time, so it can be high enough to do its job properly at all times. Hopefully that will help speed up your process significantly so you can Get Er DoneI hope this helps. Have a wonderful night.
Hello Gobbler,
If you run out of 0871 just continue to add what you've been adding. So if you've been adding 1/2-3/4 gallon of chlorine a couple/few times a day then continue to do just that, and then check your level when your reagents come in, and adjust accordingly.
Also Please put your pool information in your Signature so we know how many gallons your pool is etc. and we can better assist you. You can do this by going to the Top of this page clicking on Forum Actions---->General Settings then on the left side of your page there is a bold tab that says My Settings and under that is EDIT SIGNATURE. Here is a link that explains the kind of Info that you should include in it. http://www.troublefreepool.com/content/115-read-before-you-post
The FC level looked much better this morning, so hopefully, it will start to hold better since it is being Maintained at or above Shock level, so it can get that algae completely killed out. You are doing great!!! Have a wonderful day.
3 drops X .5=1.5ppm, so you had it correct the 1st time.
