I just finished SLAM last weekend with a successful OCLT.
Pool is clear and water looks good. (could have a bit more sparkle but we will see)
Numbers seem to have changed dramatically in directions i find suspect.
I typically follow the the TFP philosophy to the letter. This week due to the Chlorine shortage i could not find liquid chlorine when i needed it so i bought the pucks from Leslie and added 4 a few days ago. (finally found liquid chlorine and will leave the pucks in until they dissolve, adding liquid as needed, then stop the pucks)
Here are my numbers and the CSI is good but i know i will have to raise CYA in the Texas summer.
So what confuses me is the significant drop in TA and CYA, and the massive increase in CH
Any feedback and thoughts would be appreciated.
Last week's readings
FC 16
CH 200
TA 90
pH 7.2
CYA 40
CSI -0.43
Last night readings
FC 7
CH 475
TA 70
pH 7.5/7.6
CYA 30
CSI 0.04/ .14
- I have one fountain, it is one of the flowers in one of the returns.
- Due to the low CH i added 15lbs of Hardness Plus from Leslie ( i never shop at Leslie for chemicals but i was there so i did). I added this all at the same time ( kind of a no-no) and brushed very well and left the pump running for 24-48 hrs
- Historically, at the beginning of the summer, I have to lower TA and raise CH and CYA.
- I have not refreshed my chemicals (TF-100) from TFTest kits ( though i typically do that every summer) because i have unused bottles that have been stored inside in the dark
- I was adding Acid, dropped it to 7.1 twice during SLAM ( i know, a no-no), but done doing that as ph has stabilized.
FC 16
CH 200
TA 90
pH 7.2
CYA 40
CSI -0.43
Last night readings
FC 7
CH 475
TA 70
pH 7.5/7.6
CYA 30
CSI 0.04/ .14
