Good morning!
I've searched the forums but I still have a question about using NST tablets to maintain chlorine levels while away for a week.
We have a 13,500 gal above ground pool (vinyl). I use liquid chlorine (bleach) exclusively and test and record FC and CC daily. I use granulated CYA at the beginning of each season to bring the level to 50 ppm. I keep FC between 6 to 8 ppm. The CC numbers are always < 0.5 ppm. This season, we're averaging about 2 ppm chlorine loss per day and the pool is crystal clear.
We'll be away for a week and there will be no one to add bleach as needed. If I make sure the chlorine is at 8 ppm before we leave, do you think NST tablets in the skimmer would provide adequate chlorine to keep the FC at or above a minimum of 4 ppm while we're away? (Based on the product instructions, I'm thinking two or three tablets.) Because it's vinyl, I'm not too concerned about the calcium added by the product.
i don't want to use stabilized pucks and have them adding more CYA. CYA is at the exact level I want and I don't want to screw it up.
As always, thanks for any replies!
