Sorry this may be a little long. New here and totally lost! Want you to know what I’ve done so you can help me figure out what to do next.
First note: I’ve had my pool for 7 years. First 3 had a pool company, last 4 relied on a pool store and have hated every minute. Always adding something, always fighting to keep pool water clear. Finally ready to learn and do it right.
4/30 - new pump installed. Pool sat for 4 months with no pump/chemicals (a whole different story). Water was a murky dark green. Advised by pool store to add 12.5 gal liquid shock and 2 bags of YellowStop and to bring water sample in a few days. Done.
5/2 - guy who installed pump stops by to fix leak and said YellowStop won’t work and said I need to add a whole jug of algaecide. Done.
5/5 - pool is blue-ish. Water sample taken to pool store:
TC = 1.0
FC = 1.0
CC = 0.0
pH = 7.4
TA = 100
CH = 350
Stabilizer = 0
Told to add 2 gal of liquid stabilizer/conditioner. An hour later add 5 gal liquid shock, then an hour later add 8 capfuls of Pool First Aid. Also told to make sure my “tube” had tablets in it, it does and is set on 3 (of 5). Run pump for 48 hours before cleaning filter. When I cleaned the filter I’m pretty sure all the stabilizer was washed away.
5/10 - talked to pool store again. Pool still cloudy. Told since stabilizer was liquid that it didn’t wash away, that it was probably whatever is making my pool cloudy (it was a milky white substance I’ve never seen before or since). Told to add 12.5 gal liquid shock and anothe 8 capfuls of Pool First Aid. At this point I really started to read the TFP forums.
5/14 - Today my pool is a beautiful blue but still cloudy. My pump has been running constantly for over a week. I can finally almost make out the 3rd step but can’t see the bottom. I’ve been cleaning my filter almost everyday and brushing everyday. After all my reading I did order a test kit and no longer trust the pool store (not that I really did before).
Where do I go from here? I know I need to retest my water and will do that as soon as the kit arrives. Or should I make a run to the pool store? Do I just keep brushing and cleaning the filter everyday? Keep the pump running 24/7? I expect the kit to be here Wednesday.
Thanks for all all your help!
TC = 1.0
FC = 1.0
CC = 0.0
pH = 7.4
TA = 100
CH = 350
Stabilizer = 0
