- Jun 9, 2021
- 76
- Plaster
- Pentair Intellichlor IC-40
Yep. SLAM. Already. And here I thought I would never have to SLAM but I guess I have more learning to do about pools...
I was very hesitant to say it was algae because my water still seems clear, typically kept my FC at 5 or higher (except one day when changing the programing in my pool and my SWG was off for most of the day because I didn't fully understand how the intellitouch worked and it took me a day at work before I found the SWG turned off), and I also run borates. I guess that one day of no SWG did me in. My borates are at a high enough level or too high, those test strips make it difficult to know exactly how much borates I have, but it's at least 50 and maybe even 75. The colors are so close together on the scale I just have to kind of guess.
The question I am asking myself now is if I should buy a couple of flanges and a length of pipe to make a "SLAM adapter" and use it to take out my SWG during the process. I'd make a straight pipe with flanges the same length as the SWG and put the pipe in place of the SWG for the SLAM process. I've read that liquid chlorine can damage an SWG. Is that true?
