I have an inground pebble tech pool with inground hot tub at a home I bought 6 mths ago. Pool and equipment installed around 2001. Prior equipment maintenance history unknown. Pool/spa has two pumps and DE filter with hayward heater. Booster pump is hayward northstar SP4015X2ONS (2 hp) and is leaking from underside somwhere. Its not from drain plugs as I just changed orings. Guessing either a main seal or crack in pump body. Is this pump worth repairing or time to replace? Its outdoor above ground mount and all pump tags are faded and unreadable. i think all equipment is original aside from new gasket on DE filter and a new actuator valve. I don't see northstar pump model available on line for purchase by homeowner. I was hoping to replace inkind to avoid redoing all inlet/outlet piping but can if necessary. All input appreciated.
