[FONT=Helvetica Neue, Helvetica, Arial, sans-serif]I'm about ready to sign a contract for a new vinyl pool install in northern Virginia. It's been a shock at how expensive building a pool around here is and how few installers will do a vinyl pool. We are at $60k for the following. A layout I created should be attached. Opinions and insight are welcome.
Currently we are leaning towards Pentair products rather than the Hayward products listed. I realize the VS pump is over kill, but the two speed whisperflo is only a couple hundred different. Also, the automation is overkill, but I'd like to control the pool with my phone, I may add solar at a later time, and I may install led light on the fence and have the automation control it.
[/FONT]
[/FONT]
- 40 ft long free form pool (approx 630 sqft of surface area)
- Liner with >= 27 mill thickness
- 48" shallow-end wall height and 8-ft deep end
- Polymer walls
- White bullnose coping
- Backfill with stone
- Cement footing about entire perimeter of pool
- Vermiculite base
- 8-ft white steps in shallow end
- 6-ft white diving board
- 2 skimmers, 4 returns, main drain (2" pipes solid PVC)
- All Pentair or all Hayward System
- Pump: Pentair Intelliflo VS (or Hayward EcoStar VS)
- Cartridge Filter: Pentair Clean and Clear 520 (or Hayward C5030)
- 40k Salt Generater: Pentair IntelliChlor IC40 (or Hayward TCell15)
- Automation: Pentair EasyTouch4 (or Hayward Aqua Plus)
- 400k Heater: Pentair Master Temp (or Hayward Universal H-Series H400FDP)
- Color changing LED Light: Pentair Intellibright (or Hayward ColorLogic)
- Brushed Concrete on gravel base with wire mesh
- Decking: 1168 sqft of brushed concrete
- Walkway: 112 sqft of brushed concrete
- Fence: 162 ft of black aluminum fence with 2 gates
- Electrical: buried conduit from breaker box to pump location on opposing corner of house
