Non Intex swg with intex pump
Dadofthree74
122
Little Rock, Arkansas
CircuPool RJ-45 Plus
Does anyone have any recommendations for attaching a non intex swg ie edge 15 or circupool sj20 to their intex pump and pool.
I have a 4000 gallon pool and my intex swg is not working and I can get the parts I need.
my thought would be to use 1.5 in flex pvc pipe from the filter to the swg but I don’t know what the connection is on the swg inlet. And then use 1.5 flex pvc pipe from the swg to the pool.
I have made intex adapters that are attached to the 1.5 pvc already.
You can easily do that, The Edge and SJ has a 2 inch slip union connection so you will need a 1.5 to 2 inch PVC adapter.. It would be cheaper to use rigid PVC pipe :)
