Hey all - been lurking here for a little bit but finally running into an interesting problem that I am hoping to get some advice. I have tried the search function but can't really find a post specific to my issue. I recently got my first pool after purchasing a house a month ago. I decided today to open up the filter housing to determine if it needed cleaning as I didn't get any indication from the previous owner the last time it was done and the PSI was starting to creep up on the gauge. Got it off, cleaned it up, reassembled the housing, turned the pump back on and it is now operating at a much louder pitch than it used to operate at. Double checked seals and I can't visibly see water coming out of the filter. I do not see any air coming from any of the returns. When I turn the valve to pressure side, the noise goes back to the level it was at prior to cleaning. Additionally, if I run the water through the filter but turn off the floor return just leaving the return jets on, the noise goes back to the level it was at prior to cleaning. It is only operating at a very noisy level if I am running the filter through both the return jets and floor return. A couple other things that might be helpful:
- I have two suction side plumbing pipes going into the pump. Noise level stays noisy even if I turn one or the other off.
- The pump/filter is on a concrete pad that I doubt shifted in 30 minutes.
- Water level is high so don't anticipate this being a running dry problem.
- Pool pump is about a year old. Had a pool company inspect it upon purchase of the house and they mentioned it looked like it was in good shape.
Could this somehow be a result of the way I put my filter back together? I don't think it had been cleaned in a while so it was a pain to get off and get back on. It is just weird to me that if it is a result of the way I put my filter back together why it wouldn't show any leaking or be noisy whether the floor return was on or not. Any advice or additional things I could check out would be helpful! Thank you in advanced for the help.
