Edited to add: ok I can’t figure out how to attach the vids. It keeps saying the file is too big for the server to handle. It’s a 9 second vid so I’m probably doing something wrong. I’m working on figuring it out. Sorry!
Starting about four days ago - out of nowhere the suction in my pool skimmer stopped. I’ve spent the last few days reading, watching vids, taking notes, and fighting with the pool and I’ve lost every battle. Both the skimmer basket & pump basket are clean, the water level is right, I’ve backwashed & rinsed the filter several times, I’ve pushed one of those plastic things with teeth down the suction hole about a jillion times (nothing/no resistance or anything), I used the vacuum hose to “plunge” the suction hole (created little air tornadoes in the hole), and I’ve checked the pump impeller and there’s no obstruction.
The water in the pool is still circulating and water is still coming in through both return jets. The main drain is now covered in leaves and stuff because I haven’t been able to vacuum because there’s no suction. I tried turning the Jandy Valve back and forth about a hundred times but nothing changes (see attached video). I ordered a drain bladder thing for the hose but it won’t be here until tomorrow. I’m getting super frustrated and disappointed that I can’t figure out this whole pool thing by myself & I don’t want to give up and hire a pool guy because we can’t afford it & I’ll never hear the end of it from my roommate.
I attached a few vids of my pump running “normally” and then of what happens when I turn the Jandy Valve - I don’t even know which side is which - I’m guessing my left side where the water stops flowing the same is from the skimmer?
My pool is pretty much covered by huge trees so there is a constant stream of leaves, sticks, pine needles, and acorns coming down into it. I skim it multiple times a day every day. The last time I remember the suction working I was vacuuming up a lot of debris from the bottom of the pool & I had the multiport valve thing turned to “Waste”. It worked fine as far as I could tell and then a few days later when I went to vacuum again - I noticed there was no suction.
Maybe important info: I was trying clean everything I could out the skimmer and I pulled a Little Rock & an acorn head out of that other hole in the skimmer - the one that has a little square on it and I think is an equalizer maybe. When I did that - I feel like I may have pushed it down a little from it’s starting position and it stayed. The suction was already not working at this point though and I could’ve imagined the movement lol - I get so nervous handling anything pool related so I’m super tense.
I also attached a couple vids of the automatic chlorinator thing because there’s a kind of clicking noise coming from it and the pipe that goes from it to the filter is vibrating a little - it’s probably hard to see it in the video. It’s probably hard to hear too because the pump is so loud. We leave the pump on 24/7.
Sorry for the long post. Any help would be greatly appreciated. I haven’t been able to find a vid showing the type of pump I have running normally so I don’t know if that’s even working right.
Also, I think you have to turn your phone to the side to see my signature line with all my pool info in it. If anyone can’t see it - I can just post it for them here. Thanks everybody!
