- Nov 21, 2023
- 1
- Plaster
- Pentair Intellichlor IC-20
My IC20 doesn't have any lights on it so I followed some diagnostic troubleshooting advice and found I don't have any power to my transformer (Yellow and white wire to the transformer).
Diagnostics said I should have a nominal 220-240 volts. I have zero. Does anyone have any experience with this? Is this just a bad relay. I understand that you don't want any power to the SWG if the filter pump isn't running but it is ... and there is no power on the yellow and white wire. Anyone have any suggestions? Thank you in advance.
