- Jul 3, 2013
- 9,027
- Vinyl
- CircuPool SJ-40
Hey everyone, Just opened the pool from the winter slumber and wanted to share what I did..
First, I closed the pool by dropping the water below skimmer and installed custom made PVC Pipes to keep all connections above the water line during the winter. I also opted not to use a cover to see if it would work for me and how the TFP method would make it through the winter. I brought the water to SLAM level before closing, the temp was below 60 degrees and closer to 50 degrees before I closed..
When opened
FC 3 , added to bring to FC 15
PH 7.4
TA 50
CYA 70
Salt 3800
This is what it looked like when I opened and some of the new "tools" I used
After 24 hours of pump time on high, AHHH there's that TFP look
When opened
PH 7.4
TA 50
CYA 70
Salt 3800
