Hello,
Recently I had a Aqua Rite Saltwater Generator failure. I found that the Thermister SL32, 2R025 had become completely unsoldered. I then purchased a replacement and had it soldered back into place. The circuit board was then reinstalled and rewired. At that point the 230V breaker was turned on and immediately the transformer blew and fried. I later discovered that I had 2 of the 4 colored wires installed on the incorrect terminals. So I purchased a replacement transformer and installed it replacing the burned out one. After turning the power back on I had no display at all of any kind. I checked the fuse as well as the power connections and both were fine. I to have some other problem and need support in getting it operational again. I may need a replacement circuit board as I did notice a burned area at the bottom of the circuit board and lower left retaining screw. It could have shorted out there and damaged the circuit board. It is a 20K pool and was converted to Goldline Controls Inc. in 2006. Would appreciate very much some help in getting the right control board for my pool at a reasonable cost as my pool water is going green.
Thanks
Thanks
