Solar heat on. Panels on two story roof.
I was swimming in my pool this morning when the VS pump was running at 2200 rpm. Everything fine. When the VS reduced to the 1800 rpm schedule, water flow ceased in the returns. I got out and checked the equipment and the pool pump pressure increased 10 psi. My SWCG was covered so I don’t know if it showed a no flow condition. I switched the solar off, the filter pressure returned to normal, and flow was restored to the returns. This was the first time I ran the solar in awhile as the water isn’t all that cold in the mornings. I only wanted to run the solar for a few hours for a small warm up.
What do you think happened?
