I just completed a no drain acid wash on a marcite pool (16,000 gallon) using 12 gallons of muiratic acid over the past two days. It removed all the copper stains after brushing with a steel bristle brush and the pool surface looks as good as when I had it remarcited. The water is cloudy I assume from the brushing and has a a number of scum patches on the surface. PH is and AK is not even registering. As such my question is how to I now go about getting the water chemistry right? I did add about 2 lbs of PH up to neutralize the acid as well as did a partial drain and refill (running the pump on discharge while adding fresh water for a couple of hours) but the PH has yet to register.
