No display on Jandy pump
Yarzy
221
Chalfont, PA
Hi everyone,
I have a Jandy VSP pump, model VSFHP165JEP and I also have the Jandy RS6 automation system. I have tried it in Auto, Service, and Time mode and no matter what I do, there is nothing on my Pump display. I was hoping to be able to adjust via the pump. Is there any trick to getting my display working or awake so I can manually adjust it if needed? I have tried to hold menu down as well...nothing shows. Any ideas?
When you connect the Aqualink to the pump you disconnect the JEP-R control panel.
To enable the pump control panel you need to change the wiring and dip switches.
Don’t you love how easy Jandy makes things for the customer?
