I've been using the TFP method using liquid chlorine for over 2 years now, no refill since I started doing it on my own. I never had an issue with being able to add liquid chlorine every day as needed however things are changing and I'll be traveling a lot more, possibly being out of town for up to 2 weeks at a time. I do have a family member that can stop by almost every day however I don't want them to deal with the pool long term. So I'm thinking the SWG is the way to go, don't think that is in question.
I contacted a local contractor who is willing to put the SWG in asap however he mentioned that since the water is 2 years old that maybe I should just get it through this summer (Arizona) and do a refill in the early spring and then have the SWG installed, starting with a fresh base vs dealing with high TDS and hardness, etc. I think this is prudent.
So basically I need to get the water through the next 8 months without overburdening my helper, so I was thinking of just doing the chlorine pucks since I don't really care about CYA buildup as much due to the planned refill.
Does this sound reasonable? Is it a better idea to start the SWG with a fresh refill vs dealing with my current water?
I'm kinda in a bit of a bind and don't want to go back to using a pool service just to get 8 months out of the water and I also don't want to burden my family member to stop by and deal with the liquid chlorine until I get the SWG installed.
Any thoughts?
Any thoughts?
