- Jul 1, 2020
- 1,442
- Vinyl
- Hayward Aqua Rite (T-15)
This is a continuation from another thread I don’t want to hijack.
If your skimmer has only one hole as you state and you have a main drain in the deep end then you have a direct run to your equipment pad from your md. You should have a valve to control the md flow. If you leave the valve open say about 10% it'll help when the skimmer is full.
@Orion7319 You could get one of these: Amazon.com: SR-500PS Stingl-Safety Vacuum Release Systems, 120/240 VAC, DPST Dry Contact: Industrial & Scientific
Or replace your motor with one like this: BG128A Century Guardian SVRS Pump Motor 1 HP 56J 3450RPM 115/230 Volts - - Amazon.com
Both monitor sudden changes in vacuum and shut down the pump, not only protects the pump from running dry but also protects your swimmers from suction entrapment.
@Orion7319 You should be doing this anyway in order to get proper flow through your pool, otherwise, debris will collect on the bottom and require more vacuuming.
@Orion7319 If you have been thinking about upgrading to a VSP most new VS pumps also will give you SVRS.. I would consider that on the basis of saving energy too .. in your situation it sounds like a win / win.
