I got 23 years out of my conventional plaster pool even being a three test pool noob—ph, chlorine, cya.
I want to be on top of the other readings now and bought a Taylor test kit with nine tests. The pool was filled a week ago and here’s what I’ve got (low alkalinity and calcium obviously) and I need to know what adjustments and what order I should tackle them in; Total Alkalinity-40ppm, Calcium-90ppm, FC-1ppm, TC-2ppm, Ph-7.8, Cya I didn’t test because there will be none and the pool is in shade until spring and that is when I will address it.
