Originally Posted by Catanzaro
Why is it that water loss occurs mostly at night and not during the day. This is why a solar cover is recommended at night and should be removed as sun is beating down on the pool.
I mostly stayed awake in physics class and based on what I can remember I'd say the opposite. As the night air cools the relative humidity (RH) increases. High humidity lowers evaporation rate. At low enough temperatures the air reaches the dew point (100% RH) and evaporation stops.
The steaming pool is actually a sign of low evaporation since the steam is water condensing rather than evaporating. During the day the air absorbs the moisture coming from the pool (ie it evaporates) so you don't see the steam.
The only thing I can think of that would make water evaporate faster at night would be increased wind. But often that isn't the case and I don't think is being suggested here.
The highest period of evaporation should be occurring during the day.
All this is separate from the question of heat loss. Evaporation is an endothermic process which consumes heat. Lots of it. So keeping the solar cover on saves a lot of heat loss. Very noticeable at night, and would be noticeable during the day except the sun is adding heat and hiding the evaporative heat loss. Personally I keep my cheap bubble wrap solar cover on during the day since preventing the evaporative heat loss more than makes up for the reduction of solar energy due to the solar cover. On calm days with very high humidity the balance could tip in favor of removing the cover but one would have to test it carefully.
