Hi,
I am becoming a firs time pool owner. We are getting a house with a pool in north Atlanta. The home and pool were unattended for over a year. Having many expenses I am trying to learn and figure out the pool system. I am attaching the pictures of the pool and equipment. There is very little I knkow about pool systems and need any help you can provide to get me started. The immedeate questions I have is to operate the system and understand the equipment.
1. The filter pump has three suction lines and two valves. Are you able to tell what the different suction lines maybe from the pictures.
2. Filter pump discharge jas two lines. What may these be.
3. I cant seem to get the cleaner pump to run - pump #2 in the attached odcument. There is a thermostat - bottm left of the control panel. I tried to turn down the thermostat set point to start the pump but it does not start. The pool inspector report says all pumps are operational. How do I start this pump.
4. I have no idea what is pump#3 and it does not have a switch/control on the panel. What may this be and how does it operate?
5. the filter pump was running well, but off late does not seem to pump. The suction filter is only half full. Do I have to prime the pump?
Thanks in advance
Thanks in advance
