- Jan 30, 2023
- 113
- Plaster
- Pentair Intellichlor IC-40
I've owned my spa for some time but transitioned a few months back to a manual chlorine approach after my bromine-based chlorinator broke and I saw the cost to replace it. I've been having a really rough time keeping my water chemistry in order and could use some advice. In the past, I was using strips for testing, MPS after every soak and some MPS, di-chlor and clarifier weekly, along with whatever was necessary to adjust pH/TA. The water was generally clear but I was getting deposits at the water line and was having a hard time reading the color strip gradations. Then, I screwed up by missing a shock/chlorine cycle after a trip and the water got very cloudy with 0 FC. Took water in to pool company for testing several times and dumped ton of sanitizer in but could not get off of 0 ppm.
So, drained the spa on Jan 24 (unfortunately, I did NOT use Ahhsome or any other system flush before doing so), refilled, bought a Taylor K-2006 kit and did a bunch of reading to better understand how to manage the water. But I continue to have big problems keeping FC in the spa, despite the fact that it's not been used since the re-fill. For example, on Feb 12, I measured 0 FC again and the water was cloudy. Because my CYA was 39, I decided to super-chlorinate with liquid chlorine. I did this over 3 separate additions roughly 45 mins apart, testing every 45 mins, as the liquid chlorine bottle is very old (no date on it but it's been years, not months, since it was purchased for our pool) and I wasn't sure how effective it would be. I ended up adding 41 oz in total for a roughly 500 gallon spa until I finally ended up with 6.0 FC, 0.5 CC, 8.0 pH, 80 TA (adjusted to 56 after accounting for rough 30 ppm borate and 38 CYA), 170 CH and 38 CYA. This equated to a 0.22 Sat Index using the watergram wheel, so pretty good. I then dropped in 1/2 oz Acid Magic in effort to drop pH to 7.8 and bring Sat Index closer to 0. The next morning I checked water clarity and it was clear (maybe not perfect, but close).
I went out today to do the full tests and the water is hazy again and I get 0 FC via strips and via the K-2006. How could it have dropped 6 ppm in just 66 hours (or less--not sure when it dropped to 0) with no usage? I sure would appreciate some guidance here, as I'm so frustrated with the whole thing. Thanks!
