We have always had a traditional pool. We moved and decided to invest in an Aquasport 52 instead. We are getting ready to order the supplies to run our Pentair Superflo VS 1.5 HP pump. We were planning to run the wire underground from our GE box. We are running 220. I read that you need a Siemens GFI to keep the breaker from tripping. It has been suggested we order the GE 220 breaker and run underground and come up at the pump pad and attach it to a Siemens BF220A 2 Pole Ground Fault Circuit Breaker. From there, tie into the pump. Is this the correct way to do it since a Siemens gfi breaker won't fit into a GE electrical box? I have been told three different ways to do it and I am really confused. We are hiring an electrician to do the work but we need the correct supplies on hand.
