Good morning! Hard to tell if those test results are as accurate as we would like. You can ignore the test strips. The K-2000? Not sure about that one. Do you have a Taylor K-2006C or TF-100? That would be ideal. But if your Taylor kit is able to test CYA and it shows over 100 (probably due to those chlorine tabs), you'll need to exchange water. There's just no way around it. You have to do that first. Get CYA down to about 50 then balance everything else.
My easy math .......... "IF" your CYA is only 100, then a 50% water exchange would lower the CYA by half. However in many cases the CYA is actually higher than pool owners expected before proper testing, so you may need to exchange a bit more at once time or do a couple exchanges to reach your desired CYA goal of about 50.
Stay the course cjkinney1981.
You own a solid test kit and are getting good advice on moving forward now.
You will be enjoying a trouble free pool in no time.
Yes I did it the normal way first and realized I was going to be high so I did the diluted test. My results were 50 on the diluted test so I multiplied x2 to get 100 for CYA
