Trying to plan for our 16-18 day vacation. Have a family member willing to come by and add chlorine but want to make things as simple as possible for her. Have a plaster pool (maybe little plaster left), 25k gals. Had algae start after not adding chlorine in 4 days due to family surgery, so did SLAM for 4 days Have been running pump 24 hours for slam but normally 12 hours daily (have timer). Everything LOOKS great so let the chlorine drift down, chlorine did drop 4 points in 24 hours but temps were 93-95.
Last testing done with t-100 kit:
FC8, PH7.4, TA140, CYA60(kind wonder if not closer to 50 as I can still see grey dot in bottom of tube at 60).
Am doing oclt tonight to see if finished slam process. Have used cal-hype 73% for slam and have slowly convinced hubby to let me try 10% liquid chlorine for normal use instead of cal-hypo. Have also been using trichlor pucks in floaters to try and keep chlorine levels up.
Wondering if I can put our solar cover on (it looks like large sheet of blue bubble wrap to me), maybe run pump for 8 hours and have family member add premeasured liquid chlorine daily lifting a corner of the cover and pouring in.
Question:
Can I run the pump with the cover on?
Can I add chlorine with the cover on?
How do I calculate how much chlorine to use if using a solar cover?
Does it matter if the chlorine level get progressively higher while I am gone?
Do I need to get the other chemical levels down before starting all of this?( CYA, PH TA etc)
I would appreciate any suggestions. I am hoping not to come back to too much of a problem as hubby is already muttering about filling in the pool or selling the house. It took me several days of research and discussion to convince him to try following the TFP method of pool care. Don't want to screw things up! LOL!
Thanks in advance
Question:
Thanks in advance
