Hi all,
New pool owner in Seattle here, trying to get things in shape after spending a lot of time reading here (thanks!).
Coming off a SLAM I wanted to get your general advice on what's next, with the added complication that I'll be out of town Mon-Wed.
Here's my status:
- Last weekend: I did a SLAM with your guidance. Pool was in reasonable shape prior (hadn't touched pool through the winter, had started to see a bit of algae in the week prior to SLAM). SLAM took about 2-3 days.
- Mon to Wed this week: Watched FC levels drop to target range.
- Wed, Thurs: Started adding bleach daily using PoolMath app to calculate.
- Fri (just now): first full round of testing since pre-SLAM.
Current tests (I'm surprised about how good the numbers are!):
FC: 5.5
pH: 7.7
TA: 70 (or 33, see below)
CH: 180
Temp: 62
CYA: 30 (or 45, see below).
My questions:
1) CYA: I've consistently been getting around 30 (pre and post SLAM), though remember I'm a novice tester. A test at the pool store on their digital machine (BioGuard printout) last weekend said 45. Which CYA number should I trust?
2) TA: Similar question -- right before starting the SLAM, my own tests showed TA of 60, and am now showing 70. The pool store BioGuard printout said TA of 33. That and the CYA were the only main discrepancies. Should I trust my own TA number or is there a chance I'm doing something wrong?
I am aware of TFP perspective on pool stores!
That said, I'm a novice, the store people have seemed reasonably knowledgeable, and I assumed a digital machine was fairly accurate, so figured it was worth asking.
3) Out of town: Any advice on what to do while I'm out of town? I'm going out of town Sunday night through Wednesday this coming week, and I travel like this about once every six weeks, so need a good plan for this ongoing. I have a floater and a handful of tablets (Costco clorox ones) left from the prior owner. Though I want to go full-on TFP and will while I'm in here, was wondering if this would be a good chance to try the tablets given my low-ish CYA. Pool store guy said that in Seattle CYA isn't as much of a concern because of how much rain we get in the off-season. If I go the tablet route, I should probably start that today so I have the weekend around to monitor before I leave. I suppose another option is just to put extra bleach in right before I leave and hope that I'm back before it drops too low.
4) Given my test numbers, it looks like the only thing I really need to do (other than follow the TFP way ongoing) is to get my CH up. Any other suggestions?
Thank you so much!
-- Lewis
Here's my status:
FC: 5.5
pH: 7.7
CH: 180
Temp: 62
My questions:
Thank you so much!
-- Lewis
