I talked to the pool store - 20/40 silica sand, which they said is essentially 20?
I will have to figure out how to remove the weir - it is not immediately apparent, and when I've checked YouTube and whatnot, it looks like it might be daunting. I thought I might saturate a washcloth with diluted bleach and plaster that against the weir with the pump off...
No other places I could imagine algae hiding other than the filter or if I ended up with crud stuck in the impeller of the pump. We had a particularly harsh winter, and subsequently, the trees overproduced seeds. Our neighbor has an EVIL tree that abuts the fence line close to our pool and we get lots of that crud in our spring pool. Since this home is a vacation home, we cannot be here for every seed-dropping event. We came back once to have the floor drains plastered with debris and the pump pot fairly full too. These maple (or maple-type) seed are whirlibirds that are tiny enough to work their way through the mesh in the pump pot basket if they break down enough. We cover the spring pool with a leaf net, which gets most of the EVIL seeds, but not all. I cannot help but wonder if stuff might be in the pump, or is that simply not possible with all the water flowing through it 24/7?
IDK about whether or not there was still any BackUp2 (algae preventative) left in the pool when disaster struck...
I didn't pass the test again last night, but was darn close! 1.5 loss. Grrrrrrr
