Hi All,
First time owning a pool - bought house with above ground 30x15 oval with vinyl liner. Replaced the pump with 1HP doheny and replace plumbing with 2" pvc. Also bought a new cartridge filter. It's using chlorine pucks. My question is:
Purchased the Taylor K2006 testing kit, but not able to get my pool water sample to turn pink on step 2 - adding the powder with the little spoon. Gave up after 4 big scoops, since don’t want to waste the reagent and the free water testing at Lesilie’s and Van Dorhan both confirm all chlorine levels are really low 0.11/0.14/0.04.
I checked my PH 7.5 and CYA level is 100 or lower since couldn’t see the black dot before 100 ppm mark.
Seeking advice, what chlorine is the most economical to add, (home depot liquid) before retesting or is my CYA too high? Appreciate the help - thanks -Joe
