- Nov 11, 2011
- 18
- Plaster
- Pentair Intellichlor IC-40
I've been lurking around these forums for a while now, moved to a new house just over two years ago and have been going at it with the test kit the pool builder left me. I upgraded to the TF-Pro Salt as a father's day gift and gave it a whirl this past weekend. Test results are as follows:
FC 4ppm
PH 8.2+
CC 0ppm (?)
CH 450ppm
TA 110-120ppm (light pink at 11 drops, red at 12 drops)
CYA 0ppm (? - vial was completely clear when full)
Salt 3400ppm
I'm seeing some black algae forming (it isn't out of control) that I'm brushing every day, and see after reviewing the basics that I have to work on CYA and TA to get my chlorine in line. A few questions for you experienced folks:
FC 4ppm
PH 8.2+
CC 0ppm (?)
CH 450ppm
Salt 3400ppm
- Should I work on CYA or TA first or attach them both together?
- Going from my experience of my last house and pool, I feel like I've been dumping a lot of muriatic acid in my pool every week. From what I've read in the basics I need to lower the TA which should help with the amount of acid I'm using. Am I on the right track? I've applied my weekly dose of acid to get the PH down and haven't tried tackling the TA yet.
- I never really paid attention to CYA and when I tested, I never lost the black dot in the vial, so I'm thinking my CYA level at the time of the test was 0. I bought a gallon of Instant Conditioner Plus and dumped it (slowly) in the skimmer as directed. Based on the pool school recommendations I'll need quite a bit more to get the the level I should be. I've read the conditioners take a while to disperse and pump has been running for about 24 hours now. How long before I should retest?
- I'm not sure if my CC test was right or not, I'm guessing that with CYA and TA off I should work on those before paying too much attention to my FC/CC/TC, is that right to think?
- Should I go ahead and SLAM to make sure the algae doesn't get any worse? I'm going out of town for 5 days soon and don't want to come home to out of control algae!
- My last test kit had an acid demand test dropper that followed the PH test. I didn't see any instructions in the TF-Pro kit, so I added the usual amount weekly of acid and will retest PH this evening. Did I overlook an acid demand step or does TF-Pro not have this dropper?
