phonedave
- May 30, 2012
- 2,252
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Haven't seen that bullfrog mixing chamber yet, it almost makes up for the gimmicky "moveable jet packs" on their tubs. It would be a bit better with an increased surface area to slow the water down and help dissolve the 03 better into the water. This might not work well on a spa as it would turn into a mini-filter and need to be cleaned regularly so maybe that is why they don't do that.
Bleach has a lower amount of chlorine in it along with other products not intended for a hot tub. Chlorinating liquid has a ph of 11 so you'd be fighting that every time you add any. Not that it would be a huge issue to deal with, SG pools and spas deal with it all the time as it is producing liquid chlorine.
Not sure what you think is gimmicky about them. I liked the option of being able to pick what jets I wanted. I also like that fact that I can (and do) move my packs around. I'm much taller than my wife. If she wants to use the shoulder massager pack in the deep seats, the effect is lost on her as the jets are well above her shoulders. If I use it in the shallow seats, my shoulders are jammed up against the jets, so I move it to the deep seats. I also move my packs around depending on where I feel like sitting (which depends on the season usually)
Plain bleach, which is what we advocate on this site, does not have additives that are bad for a pool or spa. Also, who cares what the concentration is, especially with a spa. The amounts you add in a 300 - 500 gallon spa are small, so storage differences are negligible. I used standard bleach in a 17,000 gallon pool for years.
