Hello! Recently got a brand new spa! 400 gallon 94x94. This forum is awesome, glad to have found it.
Here is my crazy water chemistry ordeal. All levels have been awesome since we have had the spa, been testing daily, sometimes multiple times daily, with a Taylor test kit. Chlorine around 3 PPM, alk about 80-90, ph just above 7. We’ve simply been adding about 1 tsp dichlor after each use, mostly just 2-3 people in tub during evenings or just my wife and I. I’ll check it first thing in morning, if chlorine is low, I’ll add a tsp or less of dichlor. Last night daughter had 4 teenagers in it, they just sat and talked for about an hour, nothing crazy. I read about benefits of non-chlorine oxidizer so I put in 2 ounces of potassium peroxymonosulfate last night for the first time, instead of chlorine, after they got out. I went out this morning to test chlorine and it was very very low so added 2 tsp dichlor. At lunch today decided to test combined chlorine and it was 6, which I read is very high. So I went on to test the alk and it went from 80-90 every day down to 20 seemingly overnight. I thought to myself, holy cow, and tested the PH. The ph went from just above 7 every day down to off the charts low. The water still looks clear as can be and there is very very little smell when lifting the cover, smells about like city tap water. I was going to start with adding baking soda but then it occurred to me that I should ask for guidance before proceeding. Any ideas out there? Did the non chlorine oxidizer crest a problem? Should I just start with the baking soda and move on to the Ph, then work on getting the combined chlorine down? Or should I just wait until all the oxidizer is gone (if it isn’t already) and test again? THANKS!
