Hi All! Background: we bought our home almost eight years ago with this small fiberglass pool and I feel like every year is a new surprise. I kept finding TFP when I put questions out there and bought the TF-100 right after we opened (late this year, June). After opening our safety cover after a slew of warm days, I knew what we'd find: (dark green). I've had good luck with shocking at the beginning of the season, vacuuming waste by removing the filter and refilling (we have a deep well, but the water is hard for sure). This year was similar. I typically use cal hypo 68% granules to shock and maintain. When my TF-100 kit arrived, I needed to increase my CYA and SLAM for CC >.5. I was able to check the boxes except the perfectly crystal clear aspect. I've had crystal clear and after screwing up by using clarifier last year, I can't get back to it. I buy two new cartridge filters every year and switch them out weekly.
Flash to my going on vacation, where I added two pounds of cal hypo prior, had someone check the pool, and yet in three days the pool was green upon our homecoming.
I've been slamming for 8 days from a starting FC of 0.5 (brushing, testing multiple times a day, water temp is around 81)but my pool is not crystal. On day 6 my OCLT was .5 but the pool wasn't clear so I added an ounce of cal hypo and was able to lose only .5 over the entire day in sun. I've been using the pool math calculator and measuring my granules to maintain. Day 7, the temps picked up to the 90s and my FC began to drop rapidly. The past two days have been a mix of torrential rain and 85 degrees plus (the two photos were only 30 minutes apart!) Not sure what to do...thank you!!
FC: 16
CYA: 30-40
CC: 0
ph: (was 7.4 at start of SLAM)
TA: 150
CH was 326...now 575!!
8,000 gallon fiberglass inground (circa '06?)
Pentair Clean and Clear Cartridge filter system
Upstate NY
FC: 16
CYA: 30-40
CC: 0
TA: 150
Upstate NY
