- Nov 15, 2020
- 3
- Plaster
- Pentair Intellichlor IC-40
22x40 in ground plaster/mini pebble, approx 30K gallons, intellichem controlling IC40 SWG (now I know I should've went with IC60 and I should've never wasted money on )
Filled it 60 days ago and cut off pool guy just 3 weeks ago and I've been managing since.
TF-Pro Salt with stirrer is my test kit
1. I did my math wrong and went overboard on the Calcium Chloride and ended up dumping the whole bag and went from tap water CH of 170 all the way to 400. I was shooting for the 250-300 range. My ex pool guy said I should've never added the CaCl and now I run the risk of having to drain may pool earlier than expected due to too high CH. I did it at the time as my builder/pool guy insisted that my pH be around 7.6 when the water temp was in the 40's for several weeks and the CSI was around -.6 so I sneakily added the CaCl in order to make it less corrosive.
Was what he said was true?
2. I'm keeping my CYA at 40 as pool guy warned me that I'll mess up the ORP sensor. Is it still accepted practice just to disable the ORP, crank up CYA to 60 and just run the SWG based on time and percentage?
3. My FC is a bit high due to the ORP instability. Is it ok to leave it here? My pool is really clear
4. I have 2 skimmers and along with the Pentair suction cleaner I have run my pump at a high RPM in order to keep getting good skimmer action and the cleaner having enough especially when I'm running the solar heater. Would the dolphin S200 be a good investment? I have a large reef area and would like to keep it clean. I've been manually sweeping and vacuuming for now.
Thanks and this forum is awesome.
Pics below and pool math and TF-Pro kit has been awesome. Pool guy just kept using crappy strips.
