I’ve heard of alot of weird stuff falling in the pool but this is a definite first for that one!
We recommend using liquid chlorine and performing the
SLAM Process to clear up issues such as yours.
Attempting to do this with cal hypo presents 2 problems- adding unnecessary calcium (too much causes scale)
& large doses of cal hypo can cause cloudiness which further complicates matters.
You will need the ability to test with your own kit to properly slam the pool and follow the protocols recommended here- a Taylor k2006c or tf100/pro
Until you get one in you can simply add 5ppm worth of liquid chlorine each day to keep things from getting worse .
Another note- that TA value is your adjusted TA. (There’s an * at the bottom that denotes this)
It is fine & no need for baking soda so long as your ACTUAL TA is 50 or above.
www.troublefreepool.com
