I just moved and have successfully maintained a chlorine pool for 12 years but salt water pools are new to me. I opened the pool at the new house yesterday (was surprised on how clear the water was, my chlorine pool was always green like a farm pond despite proper closing) which uses an AquaRite SWG T-9 cell. Checked PH, TA, CH and salt levels (All looked good) prior to start up. Not sure if the Salt water test strips are bad but the salt level appears to be ~3200 ppm however the AquaRite is reading 400 ppm. This is the 4th swimming season and I expect the cell has been used for 3 years; however due to the pump not having a timer I am guessing it was ran 24/7 for 3 years for 5 or so months. Also the serial # is #3E15125-..... that I believe is a 3 year warranty manufactured on the 125th day of 2015; so warranty is over.
Before I start dumping salt into the pool I plan on getting new salt water test strips, however my feeling is the salt water level is probably close. Is the 400 ppm reading telling me the cell went bad over the winter? I checked the plates and they look clean. Any suggestions would be greatly appreciated.
