Hi there - just got my first water analysis done at the local store. I have a 20k gallon liner pool.
FC - 2
Total 2.5
CC 0.5
pH 7.7
Hardness 122 (got some hardness inc and just added)
Alk 100
CYA - 5 (got 2 gallons of this and added)
Salt 2500
My home test kit right now is the Pentair Rainbow 78. I did add about a 1 lb of chlorine shock to the pool to try and bust up the CC.
Here are my questions -
FC - 2
Total 2.5
CC 0.5
pH 7.7
Alk 100
Salt 2500
- My home test kit tests for "chlorine residual" - not sure how that relates to free, total or CC. Please help explain this - or maybe I need a new kit that tests for those specifically (if that exists in a home kit)?
- I have a booster on my salt cell - will this get rid of CC? If not, what is the recommended way for a salt system with the boost to get rid of CC and how do I know I have CC if my test kit does not apparently test for that specific reading.
- Where do you like to keep PH and Alk in your salt pool?
- We swam yesterday and my skin is pretty dry and itchy today... not sure if it's the CC, pH or something else causing this. I've added a decent amount of M. Acid to the pool to try and drop the pH but it seems stuck on the higher level which I know is common for salt pools.
- If I have a salt cell, should I roll with just non-chlorine shock to reduce CC for now on?
