So we bought a pool last spring, It was installed last fall, filled and covered. About 3 weeks ago we opened the pool and I was overwhelmed with the vast amount of chemicals and other pool details that I needed to learn. Like most everyone I went to the local pool store and was sold Tri-Chlor tabs, shock, clarifier, algicide, etc. I was given instructions and sent on my way. I have been chasing low FC, High PH, High TA, Low CYA, etc. Then, last week I started searching on the internet and found the BBB method and eventually found this site. The problem as I understood it seemed to be that I couldn't hold FC due to low CYA. With a new pool and CYA only coming from Tri-Chlor and Shock, as I understand it I will fight FC levels until mid season when the tabs finally put enough CYA in the pool. However, that would mean that I would start to lose FC effectiveness due to higher CYA. I ordered a Taylor 2006c and a TF-Pro test kits (I know its overkill but I wanted plenty of supplies as I need to teach others how to test, and I couldn't decide between the 2 so I ordered both). The kits will be here this week so I can finally get accurate levels. I plan to use my Tri-Chlor until I get my CYA levels to 50-60, then switch to bleach. PH was at 8.4 so, instead of the pool store PH down I added muratic acid (quantity based on the TFP AP). From here on out I plan to only use Tri-Chlor (until I run out OR get my CYA levels where I want them) Bleach, Baking Soda, Borax, Muratic Acid, and aeration to keep my pool in check. I'm not sure if I am going to continue to use my shock or sell it on FB or use the SLAM method right away as needed. Lastly, I am eliminating the mineral cartridge in the nature 2 today. Any input or advice is appreciated.
