My pools has been running fine for the past 2 years or so. In the last few weeks I noticed my automatic pool cleaner wasnt moving. I checked it out and found there was no water coming from the port on the side of the pool (where the automatically cleaner attaches via a long tube).
I thought it might be the filter at the pool pump. I turned the pump off and cleaned out the basket, now I cant seem to get the pump to prime well. The filter basket is about half full of water and I can see the water going from the skimmer/main drain and flowing into the basket. The flow just isnt very strong (ie reaches the top clear plastic lid of the filter basket). I noticed the jets on the side of the pool aren't flowing anymore either. Is this level sufficent for the main pool pump? Or do I need to prime it better?
I tried searching online for instructions on how to prime the pump and found two which I tried:
#1.
Turn pump off
Set multiport to recirculate
Fill filter basket with water & close
Turn pump back on
---I tried this about 5 times, each time the water just drained from the filter basket. I also noticed the air relief valve started sucking in air when I opened it
#2
Turn off pump
Keep multiport on filter
Turn of main valve and one skimmer valve (I have a main valve and two skimmer valves)
Open air relief valve
Turn pump on
When water comes out of air relief valve close valve and the pump is primed slowly open main and skimmer valve
---I tried this about 10 time today. It at least got the filter basket to remain filled 1/2 way and pump water from the skimmers/main. Most of the time the air pressure valve would shoot out air.
So Im not sure what I'm doing wrong or if I even have the right instructions for priming the pump. I've attached images of my setup if anyone could help me out!
Thanks for your time!
Michael
#1.
Turn pump off
Turn pump back on
#2
Turn off pump
Turn pump on
Michael
