Hey everyone, new pool owner and new to TFP here. I just bought a house with a 9,000 gallon plaster pool, and my chemistry is a bit off. I have a k-2006 test kit but was having trouble getting a FC and CYA reading. I took a sample to Leslie’s and they read the FC as 23 and CYA as 167. These crazy high numbers explain why I was having trouble with the k-2006 giving accurate readings.
Now I understand that to effectively get the CYA down to a reasonable level I should drain and refill the pool, but I live in Phoenix and my plaster is not in great shape. I’m hoping to limp it for a year or so before getting the pool resurfaced so if at all possible I’d like to avoid draining for the time being. Is it safe for plaster in the AZ heat to drain 6-12” and refill? Any other advice on managing these numbers through the summer?
Side note, to my knowledge the pool has only been chlorinated with tabs in a floater, which explains how the CYA got to this level. After seeing these numbers I pulled the floater out and plan to start using liquid chlorine when the FC comes down a bit.
