New to BBB but it's defintely working!
Aug 22, 2009
19
Largo, FL
Lil background, we just moved into a house with a pool, an unmaintained for 2+ years pool.
So I started off hitting Leslie's and going that route, spending a lot of money and not really seeing any result, then I find this site.
After just 3 days doing the BBB method, after draining 1/3 of the water and refilling, my pool chemistry is spot on perfect.
I just wanted to say thanks to all of you as this will definitely be the way I keep the pool from now on.
The stats:
FC: 5.0
CC: 5.0
pH: 7.6
TA: 130
CH: 200
CYA: 40
TDS: 1000
Welcome to TFP
I hope your second number where it says CC:5.0 really means TC:5.0
CC of 5ppm indicates problems, while FC and TC of 5ppm indicates good water.
drewspool said:
JohnT said:
Welcome to TFP
Whoops, my bad there, yes that should be TC.
Then you are in good shape!
It's sort of a personal choice. Most folks here on the forum use shock level as a high end for entering the pool. I will swim at higher levels but am in the minority. (Shock level is certainly a good, safe choice)
Here's where we are now:
Here's what I started with:
