- Sep 22, 2019
- 6
- Plaster
- Pureline Crystal Pure 40,000
11,000 gal pool, new Salt System with a T-9 cell rated for 25,000 gal, but can barely maintain 2.0ppm of free Chlorine with a system setting of 90%.
The running cell voltage is 24.3V, at 4.4A - which is perfectly normal according to the system manufacturer.
Salt level is at 3400ppm, Temp 89F. Pool water looks sparkling clean, with no indication for algae growth.
Chlorine <2.0, pH 7.6, Alkalinity 100, Calcium 400, CYA 90, LSI 0.02
The question is, why do I have to run this new cell so hard at 90+ %, for 8 hours, just to barely maintain a minimum Chlorine level?
I'm trying to achieve Chlorine levels of about 4.0ppm, to have adequate sanitation levels for the high CYA level.
I would expect 40-50% with a T-9 cell for an 11,000 gal pool, is this reasonable?
Can the cell be bad and not produce enough chlorine, but still display normal Voltage and Amp readings?
Can be something in the water that consumes all the Chlorine?
Looking for advice.
Looking for advice.
