- Mar 11, 2024
- 88
- Plaster
- Pentair Intellichlor IC-20
Ok my kit does have those in it, but no directions for use.Get 5ppm FC in there and maintain a 5 daily for now.
Testing under 30 CYA is sketchy at best. Add 15 ppm and wait for it to register.
Lower the PH to a high 7.
Test your tap water CH and we'll go from there.
Order a taylor K1766 from TFtestkits.net if you want it guaranteed to come fresh or Amazon if you want it only guaranteed to come.
*edit. I see you bought the salt kit. Double check your receipt for TF100-salt.
Then double check the kit for chromate indicator and silver nitrate bottles. (Yellow and orangey brown)
I put 81oz of bleach in a couple days ago and the chlorine went up, but it didn’t last.
What do I use to raise CYA?
