My pump and filter are sucking a lot of air. I have tried all the DIY fixes at the pump and the lines above ground and have been unable to fix the problem. (Even had a pool company out to check it and they could not find an air leak above ground.) Next step is for pressure test/ leak detection which will be done this week. My current suction line is flexible PVC and I understand this is not used anymore in new swimming pools, so..... I may be looking at running a whole new suction line. I'm wondering if anyone can give me a ball park estimate for what I should expect to pay if i do end up replacing the entire suction line. Here are the details:
- will need to cut and remove about 2' x 3' area of concrete and dig to get to bottom of skimmer
- dig a trench about 40' from skimmer to a point where the pipe runs under a wooden deck
- run about 75' of rigid PVC from the skimmer to the pump (about half of it above ground under the deck)
- replace one ball valve and attach new line to pump
- refill trench and replace concrete
