- Jul 24, 2020
- 277
- Plaster
- Jandy Aquapure 1400
Hey folks.
My solar install went in over the last couple of days (with massive bonus points to the company for also moving some PV electric panels elsewhere on the house to make room), and today is the first full day of use.
I noticed it immediately during the walkthrough yesterday but wanted to give it a few more hours to be sure, but I am pretty sure I have a vacuum issue. When the pump flips into low speed, I can hear the VRV pulling in air, plus lots and lots of large bubbles in the down pipe from the roof, and coming into the pool.
A few notes:
- The panels are installed on garage roof (first story). Lowest end is probably 10ft, and highest point is probably 16-18ft.
- I asked them to plumb it 'opposite end' style instead of send/return on the same end to absolutely make sure that the water is forced through the entire array and won't try to sneak through the shortest path (even though the Fafco recommendation is for same-side)
- VRV is installed at the very top of the system, on the send side.
- Freshly filled pool (last weekend), with clean filter (also cleaned last weekend).
- Pump pressures read: High Speed: 16psi, 27psi with solar on. Low Speed: 0psi (needle does not move), or 7psi with solar on.
- Low speed pre-solar runs a combined 18gpm or so to the pool. I haven't measured yet post solar, but the water speed at the return eyes feels much lower.
I will attach a picture of the plumbing in the next post. Based on my reading of all the threads here I think everything looks ok (except arguably the SWG being before the panels). Since I have a robot vacuum I have bypassed the booster pump (the hose) and I plan to cap that off soon.
Any thoughts? My first idea is to move the VRV from the top to a lower elevation (so maybe the lower end of the panels) to see if that helps. Ideally I'd like to avoid having to switch out the pump for a variable speed, and I definitely don't want to have to run the whole thing on high all day long.
Thanks!
A few notes:
Thanks!
