- Jun 24, 2021
- 16,349
- Vinyl
- CircuPool RJ-60 Plus
Typo. 12 hours should be fine.Also, 112 hours? As in 4.5 days?
a typo. 12-24 hours after salt is added, you can turn it back up from 0%You are super helpful. I REALLY appreciate your patience with me. I am committed to learning this, and some things are starting to click for the first time.
I guess I need to see how to turn the generator off... haven't tried that before. Also, 112 hours? As in 4.5 days?
Good morning. So yesterday is when I finally had a chance to tackle some of this.Salt level need to be 3000-3500ppm for the cell to generate. You need to add salt. Turn the generator off when you add salt for at least 112 hours with pump running. Maintain FC for your CYA with liquid chlorine while the salt is mixing...Link-->FC/CYA Levels
. Put the salt in and brush until it is dissolved. Use Diamon Crystals Solar Naturals or diamond crystal pool salt...Link-->FC/CYA Levels
Clean strip is somewhere around 15-20%...MFger doesn't disclose...you will have to play with it. Chlorine at least 10 minutes after or before acid. You did good.
Get and keep your FC up for your CYA. What is your CY> Follow this
I have printed SLAM instructions.
Yes, that sounds like a good plan. I will plan on doing just that.I'll leave the FC mystery to others here, you are in very good hands. My comment is peripherally pertinent. If it's not too late, don't throw away the previous SWG. There may not have been anything wrong with it. Once you sort out the FC issue, it's very possible the old SWG will happily produce chlorine.
I would leave the new one in place, until its warranty expires (might be one or three years, check your docs), and then reinstall the old one to see if it has any life left. If so, use the old one until it's dead, then re-reinstall the new one. In the meantime, keep the old one in the new one's box, and store it properly. If it does have life left, it will likely still be OK years from now.
I'm suggesting you use the new one through it's warranty period, as opposed to trying out the old one now. Might as well take advantage of that warranty, instead of letting it expire while it's on a shelf in your garage.
I had a similar situation, and my old one is in a box, and might be for years, waiting to fulfill its destiny someday! It's also serving as a back up. If/when my current SWG dies, I'll be able to install the old one while awaiting the arrival of the next one.
Good luck with your FC.
So last night I added the recommended amount to raise my CL to 16 (which was 400oz of Liquid Chlorine).Yes, you are correct. The more often you can test and replace the better. No more often than every 2-3 hours. SWCG off.
Completed my first FAS/DPD test. CL was 8.5 so I added 202 oz of chlorine (to hopefully get me back to 16) and CC was 0.5.Use the fas/dpd powder test for FC. The block test is horribly vague at best and also inaccurate. It's for spot checking that you have a presence of chlorine once you're at one with the pool. At that point, when you're sure it's above 5ppm still from yesterday and the block is taxicab yellow, you're probably right.
I guess I have either been a little distracted today, or perhaps just confusing / mixing up numbers....The name of the game is to replenish to slam as often as you can, no sooner than 2 hours at a clip. We all have life in the way, do the best you can. Go right until bed.
As the process plays out, the FC holds better between doses. When it's mostly holding 3 hours, go to 4 hours. Then 5. Etc.
You can dose early at any time to buy yourself the next block of time away, or lessen the time under slam if longer.
Ph is invalid at 10+ FC. The rest of the parameters don't matter for now. You won't lower the CYA anything appreciable with cartridge cleanings.
Brush and vac at least once a day. Each swipe may remove another layer of biofilm on the walls/floor, exposing more algae to kill.
You got this.
GREAT NEWS…. It took all week, but FINALLY I have successfully completed SLAM.It's all good. You may burn off a couple extra ppm today from the higher FC level, but most will be there for what you need. If you wasted 2 FC to the sun, I assure you, you won't lose your house over it.![]()
Our Mustard algae slam FC (60% of CYA instead of 40%) is safe for 24 hours, you're well below that and will be back to regular slam FC soon. Totally no harm in any capacity done.
And it was 15 last night ? No traces of algae whatsoever ?CL was sitting on 15ppm this morning…. But now what?
Your cell makes about 7 FC per 24 hous. It's easiest to round it and say 1 FC every 4 hours at 100%. You can mess with effects of adding in the upper left menu in poolmath so see what different hours and %s will produce.But now what?
Yes overnight it went from 16ppm to 15ppm this morning. Zero traces of algae.And it was 15 last night ? No traces of algae whatsoever ?
Then produce enough per day to remain free and clear of min FC at the low point of the day. (Afternoon/evening depending on runtime).
Set it for the high loss days for that point of the season. Accept it will over produce on the cloudy days. I adjust mine when it lands beyond 8 to 12 FC.
