New Robotic Pool Cleaner - Help!
lodi
35
Atlanta
I know there are lots of posts about robotic pool cleaner recommendations, but I wanted to list my specific needs to get the best recommendation. My Polaris 9450 finally failed. I think water got into the cable connection on the robot. Besides this, its pretty beat up. It has served us very well for seven years. No complaints at all.
So, I’m ready to buy a new robot and I’m blown away by the vast array of models offered by each manufacturer, and they all seem so close to each other in feature/function. At the end of the day, I want to drop a robot in the pool, press a button and have it do its job. Cool features are good if they are something I’ll use. I’m wide open with regard to manufacturer, model and price. I do like the fact that the Polaris has a caddy but thats not a deal breaker.
Our pool is large, probably 40K gallons. It’s 50 ft x 15 ft at the wides point. The shallow end is 3-4 ft and the deep end is 8 ft. It has one small bench and a tanning ledge. The Polaris didn’t go onto the tanning ledge which is fine. It also has a large vanishing edge tank that I would drop the Polaris into periodically, so whatever I get needs to be nimble enough to navigate the VE tank (probably 4 ft wide by 25 ft long). I assume most are. Like I said, the Polaris did a good job. If I had any gripes they would be bin capacity and speed. Due to the size of the pool I would often have to empty the bin and send it on another pass. Two passes was probably 4 to 5 hours. We do not cover our pool in the winter so it has its work cut out for it during those months.
Given that the 9450 was a fairly basic machine, are there must-have features that I should consider? Maybe knowing this will help me wind down my choices. Is mobile app important? If you have a specific brand/model that is working well for you in a similar pool, please share. I’m not too worried about price, but if a $900 cleaner will work as well as a $1,500 cleaner than I will certainly go with the value decision. If the high-end unit is truly better then thats fine too.
Priorities: gets the pool clean with no fuss, reliable, reasonable speed, reasonable capacity, parts/service availability.
Thank you in advance.
Dave
This is fairly popular and the one I own and I am pretty satisfied with it.
I've had my Pentair Warrior SI for over a year now and couldn't imagine living without it. My advice is to get any of the variants that have the top loaded basket. I don't think wifi or bluetooth connectivity is worth the premium; the basic robot does a fantastic job out of the box.
Marina Pool and Spa offers best pricing, by far. Here's what they have in stock currently:
Reactions: HermanTX
I have a Hayward Tigershark QC. It was given to me "well used" as a hand me down. I've been using it for 2 years no problems. When I was at the pool store I saw one new in the box with a customer name on it. I asked the store owner about it and they said it was ordered specific for a customer. They said the guy wanted the same model since it originally lasted 10 years. When mine goes bad, I'm buying the same thing.
Thanks for the help guys! I picked up a Dolphin E70. Got a good deal from Marina Pool, plus I received a rebate form from Maytronics so hopefully I’ll get a few bucks back. In either case, If it lasts four or five years its worth the extra $$. Nice machine. I like the mobile app. Initial impressions - It’s heavier than the Polaris so its a bit harder to lug out of the pool. Not a big deal. Just worth mentioning. Also, the Dolphin basket takes a little more work to clean out than the Polaris. I could just rack the Polaris basket on the ground and drop it back in. The Dolphin basket needs to be rinsed. Performance-wise, its great. Very fast compared to the Polaris, picks up very fine debris, and does a better job at cleaning the waterline. Keep in mind that I’m comparing it to the Polaris 9450. I’m sure a higher end Polaris would be a more even comparison.
Reactions: HermanTX
Does it clean your tanning ledge?
No. It does not clean the tanning ledge. For both my tanning ledge and my vanishing edge tank, I give them a good brushing one or two mornings a week and let the filter system take care of the rest. I used to drop the Dolphin in the VE tank but its really not necessary, at least during the summer. I’m liking the Dolphin more and more. I had a control unit go out on me and they replaced it in a matter of days so good customer service too.
Reactions: Aquagenarian
