- Apr 23, 2017
- 2,400
- Plaster
- Hayward Aqua Rite (T-15)
So I ordered new refills for water testing and they are much different. Example: I tested my CH with last years R-0012 and results were 375-400, then I tested with new R-0012 and results were 500-525! I waited 3 days and retested with the exact same results from both R-0012's. Mind you the old R-0012 is a year old...
Any ideas as to what is going on with such different numbers? Should I call Rebecca at TFTestkits?
I don't see the need to drain some of the water since we are starting to get high outside temps (mid to high 90's) so normal evaporation and pool use will take care of it.
Thanks for your thoughts...
