Graduating from 12 ft round intex with the pool In my signature. Hopefully I’m on the right track. Wanted to get ahead of installer because it will be a shotgun start when the weather breaks here in Northwest Ohio. Going to run 2” PVC to the pool about 50 feet. Put the equipment pad on a 6 x 4 treated deck close to utilities. Mock piped for now no glue yet just to make sure I was on the right track. Suggestions welcome. Jandy check valve on the way from amazon for after the heater and before the SWG Also I purchased clear primer and glue rather than purple as I am a bit sloppy. Curious as to why you would you use purple anyway? Just curious? Any difference?View attachment 135573View attachment 135574
